Hardware sugestions on GPU and rest hardware.
Can anyone make suggestions on hardware specially on GPU. How GPU depended is these 2 software’s?
- Bentley descartes
- Bentley Context capture
So should I move towards Quadra card or 1080 is more than enough or even 750ti gets the job done.
can anyone explain when is used parallel or when is used reconstruction process? And depended on that I believe if you use parallel you need more core if reconstruction then faster threads. I don’t now how exactly that software is working but what we do is from pictures getting points and something like that.
I can't rly understand because I am IT guy and don't know what that software is utilizing
  • Hi,
    For Descartes and ContexCapture it is better you buy a Geforce GTX 10 series card with 8GB GDDR.
    Do not buy a Geforce Titan because this card is slower for this.
    Geforce is faster in 3D when rotating point clouds or big data.
    Quadro is for static view applications (foto viewing, etc...).
    Quadro provides a better and more accurate picture on your screen but is slower when rotating point clouds.
    When rotating pointclouds, the screen layout will be more shocks rather than smooth whit a Quadro.
    Grtz,
    Werner
  • Yea I understand that. Bat the question is for rendering not for only weaving picture. Basically client have pictures from remote plane or drone and they need to render 3d image, how it’s working on CPU and how GPU, they are thinking to build new computer. But they don’t now what exactly to build. So rendering part we need to understand to what direction going.
    So far seemed like each core is used fully so we are interested to build 2x Xeon, because x99 chipset is 128 GB RAM limitation, but Xeon limitation is almost none. So we are interested what GPU should be the best.
