Good morning.
I have just started at a new company and been asked to check which version of Descartes I need to have to run with Microstation V8i (Select series 3). I can't find the information readily. Any thoughts or pointers.
kgb
Hi Kenneth,
the only available version of Descartes for Microstation SS3 is: 08.11.09.601.
Since the Microstation version compatible is: 08.11.09.608 but it is not longer available, I suggest to you to submit a Service Request in order to check if your Company is eligible to obtain the Setup file here:
http://apps.bentley.com/srmanager/ProductSupport
regards
Mara
