Good day
I seem to be experiencing an issue with the weather setting in LumenRT. Any amount of clouds added to the scene seems to make the sky background flicker. Please see the attached video output i get when rendering the scene. The only work around i have is to make the weather clear and not have any clouds at all. Is there a specific reason why this happens?
Hello Elroy,
when you exported the model into LumenRT you should check few things.
1. the camera setting must be 50% so that the movement of your fly through mode is smooth. As you can see in the Snape short
2. the model once exported into LumenRT can be move to any location in the scene, you just have to unlocked this, you can see the Snape short below.
this to things might help you.
Ankur
