I was provided a Drone point cloud that has 8 million points with a .las file that is 273 meg. It is too large to use as my existing surface .dtm file in Inroads. Some of these points are less than an inch apart horizontally. I would like to thin the points to no closer than 1 foot apart horizontally. Can I thin these points with Descartes and export a file that can be used in Inroads? I have Microstation SS4, Inroads SS2 and Descartes for Microstation. I can install a newer version of these products if I need to thin the point cloud.
When importing the LAS file one of your options is to enable Spatial Filtering. When you don this you will be able to set the spatial .
