Why? ContextCapture center engine error:Graphic card has insufficient capabilities GTX1080
1、ContextCapture Center Engine warning message
Geometry shaders v4 are not supported
Vertex shaders v4 are not supported
Fragment shaders v4 are not supported
Framebuffer objects are not supported
Vertex buffer objects are not supported
Shadow mapping is not supported
Integer texture/framebuffer  is not supported
2、ContextCapture Master Center Edition tile state:Failed during photos pairwise matching
3、Software version and workstation configuration
ContextCapture center version 4.4.0.338;Tile Target RAM usage 46GB;E5 2650v3*2+128GB RAM+Dell GTX1080
4Replaced by two different brands GTX1080 graphics card will still appear this error. Generally, the next tile will be reported. Reboot invalid, re-install the graphics driver is also invalid. Shutdown for some time will return to normal but the duration is not long, the hardware detection no problem. Replace the quadro m4000 does not appear this error.
