Cant build 3D model from Pointcloud data (*e57) using Contextcapture edition.
Hi all, I am a new ContextCapture user, the first time I have a pointcloud data (*.ptx file) (850000000 points) but I only have ContextCapture Edition version. So I tried to clip apart of the data using Autodesk software and this software can help to export the data to *.e57. But when I import this file (*.e57) to ContextCapture and use this file to build 3D model the result is not ok. You can see the file and Image that are attached below.
Anyone can help to explain why is this, What should I do to build 3D model from this data. Many thanks.
Parents Reply Children
