Hi!
Please help me with moving project to compute on cluster. At this point I cannot run it even on one Engine machine, which is not the same, as Master. The job starts and fail right after the start.
I have a number of computers with different hardware configuration. One of them is say Master (where CC Master is running), the other computer is for Engine run. The third machine used as file server – there is shared folder which subfolder is set for photos, projects and job queue. So, the job queue folder is set the same on Master and Engine machines: \\fileserver\sharefolder\ContextCapture\JobQueue. It seems to be ok because when I start engine on the Engine machine I see one listening engine in the Job queue monitor run on Master.
I have done several attempts to run job on the Engine machine. The first was when I moved my project from local folder on Master machine to the fileserver machine and everything was set via network drive letter Z. I liked to use network drive more than UNC because it would be easier to change project and photos location in future if I need to move my folder from current file server. But I got this problem of cancelling job right after the start.
I have updated all paths in my moved project to the new location: photos paths updated via reference manager – status Accessible. UNC paths and Job queue path in the project options tab also updated with new location of the project and job queue - using Z network drive. Job also fail.
At this momend I paid attention to the non UNC path warning. Ok, good bye network drive, hello direct UNC naming. Everything appropriately changed:
Job queue in CC Settings Project location and job queue in project options tab Resource paths
Master and Engine rerun – fail again… Ok, may be I forgot about some path update in my moved old project. So I created new test project: 1. Created project using path via fileserver network name, not network drive (heh). 2. Created one block with one photogroup 3. Start aerotriangulation… Useless – again fail right after is starts after some small pending time.
CC Engine say: [2017-Apr-14 19:05:43] Job "job_20170414T170539_ctest2_B2_AT" failed after 00:00
:00
CC Master say it simply cancelled despite of job log is in the Failed folder:
<?xml version="1.0" encoding="utf-8"?>
<Job version="1.2">
<Type>AT</Type>
<ProjectPath>//fileserver/sharedfolder/ContextCapture/Projects/ctest2\ctest2.ccm</ProjectPath>
<ItemPath>Block_2</ItemPath>
<SubmitTime>20170414T170539</SubmitTime>
<StartTime>20170414T170543</StartTime>
<EndTime>20170414T170543</EndTime>
<SubmitHostName>MasteMachineName</SubmitHostName>
<SubmitUserName>MyUserName</SubmitUserName>
<RunHostName>EngineMachineName</RunHostName>
<RunUserName>MyUserName</RunUserName>
</Job>
Engine: i7-4790/RAM 32Gb/GeForce GTX 750 Ti(2Gb)/win8 in domain/v.4.4.0.344Master: i3-4150/RAM 32Gb/GeForce GTX 750 Ti(2Gb)/win8 in domain/v.4.4.0.344
I did everything under my domain account name with all administration rights...
Please help, what shoud I check now? Is there some more detailed log where the fail reason is described?Thank you in advance and have a nice weekend,
Sergey
