My processing workflow has taken data collected in projected coordinate systems with NAVD88, perform AT and reconstruction with the data still in its original coordinate system and vertical datum. I convert it to WGS84 in an i3s production. Upon bringing the .slpk files into ArcGIS Earth, it becomes evident that the data is floating 250-300m above the ground surface. I believe it is coming from a problem with Context capture's vertical datum shift capabilities, but I'm not sure. Has anyone found a way to fix this yet?
The scan is aerial LiDAR (LAS), which I colorized, clipped, and converted to E57. I can email you a link to the file. Before updating to the most recent version of CC, I had been able to make a full reconstruction from the aerial survey, so I'm wondering what has changed to make it no longer work.
