Hi there,
I am experiencing an issue with the 3D grass texture in LumenRT. It looks fine when I am in editing mode, but after I render a video I notice the grass texture momentarily disappears as I approach/move away from a grass area in the video. I have the same issue with each of the grass textures (e.g. 5cm, 10cm and 15cm). Has anyone else experienced this and found a solution?
Matt
Hi Matt,
please remember to put every questions related to LumenRT into Visualization forume here: https://communities.bentley.com/products/microstation/microstation_visualization/f/19754#pi20290=1
Anyway I was not able to reproduce your issue, maybe it is related to your file.
Are you able to attach it here? or if you prefer you can use our secure upload: https://communities.bentley.com/help/w/be_communities_help/18842.inserting-and-attaching-images-videos-or-files-to-communities-content (please to let us know when you attach the file and its name)
regards
Mara
when I said to see the file, I meant we need the *.lrt file, not only the video on YouTube.
As you can see in my video below, I am not able to reproduce your issue:
