edit .e57 file to ad scanner positions
I'm using a phab 2 pro smarthpone with Tango technology to get a point cloud, in .ply format, and scanner positions in a RGBD-SLAM file. I want to combine this with pictures of the object to get a better textured model.
I converted the .ply into .e57 using CloudCompare and imported to ContextCapture.
As static scans the .e57 file has no positions so origin is set to 0 and won't match the Aerotriangulation in neither position, orientation, nor scale:
As mobile scans i can import porperly both files but i get this error:
So, is there a way to manually add the positions from the RGBD-SLAM file to my .e57 file, or the timestamps. Or what would be the best way to proceed with my source files (.ply and .txt positions).
Please help and thank you for your time.
Sergio Wojtiuk
WHY inc.
