Combine point clouds and photographs in ContextCapture
Hello. I have a problem importing point clouds in ContextCapture.My task is to combine photos and scannings from Faro Focus 3D X330. I have taken GCPs  with ASHTECH(i use same GCPs to photographs and to scannings). I first made the Aerotriangulation to photographs. As for the scannings i use Autodesk  Recap Pro and i exported the registered point cloud in e57 format.Then i imported the point cloud to JRC Reconstructor to georeference it.I did the procedure and finally when i tried to imported it to Context Capture, it "put" the point cloud above the Aerotriangulated photographs.What am i missing?
I wiil appreciate your help
Parents Reply Children
