Descartes update 1 Accudraw setting issue?
I have met an issue in Descartes update 1.
After open accudraw setting dialog, in operation tab, uncheck the "context sensitivity", then start to draw a smartline with accudraw active, when I type R,Q on the keyboard I didn't see the compass on rotation mode as before.
If I check the "context sensitivity" option, draw a smartline, with accudraw active, then press RQ, the accudraw compass will roate.
There is another problem that whether I check the "context sensitivity", when I drawing, the compass will still keep its orientation with view, accudraw compass will never follow the drawing stuff's orientation.
I don't know if this is a new update or this is an issue. So I need some help.
Koalar
