Hi
The situation is that I got a computer with ContextCapture. Users will access this computer with their ID to use CC. Every user login will create a job folder under My Documents when using CC engine. They need to change their job queue folder to a public job folder (where have 10 engines standby). Is there any method to set the default job queue folder to all user?So that the new users do not need to change the job queue folder by themselves.
You can set the default job queue directory by opening CCsetings.exe (from your ContextCapture\bin\ folder) and click on Configuration tab:
Best regards,
Pierre
Answer Verified By: Felix James
Thanks PierreBut I'm looking for how to change the default job queue directory during installation. In my case, there are many users of CC Master. When they first login to the computer with CC Master, I wish the Jobqueue directory is correct. Is this possible?
This solved my issue. Thank you.
Thanks Pierre!
This completely solved my issue.
resolvió mi problema, muchas gracias
