I am trying to build a 3D model for high-resolution images(6000 pixels*4000 pixels, 350dpi) taken by drone using ContextCapture. And my ContextCapture version is 04.04.05.36(x64 update 5, English). It turned to be a failure as it took quite a long time, which seemed to be stuck in somewhere. ContextCapture worked well when taking resized images(600 pixels * 400 pixels). Is there a parameter that can control the image size which ContextCapture will handle? Thanks.
Dandi
Hi Farouk,
Thanks for sharing. I guess overlap among my images are not enough and that could be the dominant reason of my failure.
Farouk Rohoman
Thanks for the advice. I have not tried with tie points while I applied keypoint match algorithms on given images, which could generate corresponding match pairs if there are sufficient overlaps. However, it does not show enough match pairs, and that's the motivation of my guess. I will try tie points later.
