<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>descartes no response</title><link>https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/138609/descartes-no-response</link><description>When I put more than one solids from one level to another level, the program will Caton for a long time, but in the V8i version, this operation is very smooth, almost immediately completed。</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: descartes no response</title><link>https://communities.bentley.com/thread/419735?ContentTypeID=1</link><pubDate>Tue, 18 Jul 2017 15:01:23 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:706da13a-e947-45ec-901d-30aaadd4d9ef</guid><dc:creator>fmcallis</dc:creator><description>&lt;p&gt;I filed Defect 724866 for the issue that you are seeing in Connect Edition where it takes a long time to change 3D Parametric Solid elements from one level to another level.&amp;nbsp; So far the best workaround we have found is using the Change Element Attribute command.&amp;nbsp; I am assuming that this is the same issue that you opened the Service Request for the same issue.&amp;nbsp; It seems to have to do with multiple levels in the same area.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
