Failed to read project file, Is there any way to solve it?
Hi Felix,
I have the same problem "Failed to read the project", and I want to fix it. Could you tell me how to fix it? Or, I send you the *.ccm file? (Also you can download the file via the link http://pan.baidu.com/s/1o82ueVo)
Hi Guo,
The CCM file alone is not sufficient. Please do as we requested with the previous project file. If restoring from a BAK file fails we require that you send a copy of your project file (*.CCM) and a screen shot of your Windows Explorer view of the Project Files folder
I have uploaded the files and the screen shot of my Windows Explorer of the Project Files folder.
Hi Chuxian
I have a solution for you to try. I will send you a download link privately.
I have the same problem "Failed to read the project", and I need to fix it. Could you help me with fixing it?
