hello ,I need to annotate the elevation value in the tin model ,but it can only annotate whither the xyz values together?Can I only annotate elevation values without tagging XY values,In the Descartes geographic information model?
Hi, can you clarify your question? What type of data are you working with and what tools you are using?
Pascal
