Is anyone else having issues bringing in a .3mx file into connect and the coordinate systems not matching? The .3mx is created along with a .las file. When I import the .3mx using US survey feet it will only come in at the correct coordinates if the .dgn is set up to meters. If you set it up to US survey feet it scales the drawing up into the wrong location. Therefore it is impossible to bring in the .3mx into a .dgn with US survey feet. The .las file will import into the correct location just fine with US Survey feet.
Hi Jacob, is the 3MX production referenced? If so, are you applying the 3MX GeoCS when attaching the mesh to the DGN?
Pascal
