Is it possible to merged completed productions into 1 single file? I have made all the SRS, tile size, coordinates origin the same.
I have tried doing this but the model failed to open as it says that it is corrupted. is there a more detailed way of how to merge these productions into one 3D Mesh model?
- Create a directory …/Merged Production/Scene
- In this directory (…/Merged Production/Scene) Copy P1.3MX and rename it Merged_Production.3MX
- Copy also (in this directory …/Merged Production/Scene) the two Data folders and rename them Data_1, Data_2
Dear Jerard,I am writing to inform you that I have the same problem. I produced two productions which they have overlaps, but when I want to merge them according to your mentioned link, the "Failed to load the 3D scene" error appears. I would be grateful if you could help me. I am looking forward to your response.
Hi Saeid,
The error you're experiencing is normally due to an error in the merge file you have created. Have you checked the link above and does your file look similar to the example?
Most of the time it will be a very small issue in the script that causes the issue.
Jed
Dear Jerard,Thank you very much for your response. I have already merged two productions, but they had not overlaps together. But this time their tiles have overlaps and the mentioned error appeared. I have copied the text of my merged 3MX file.{"3mxVersion": 1,"name":"3MXmGeomEnd","description":"Scene generated by ContextCapture, copyright <a href='http://www.bentley.com' target='_blank'>Bentley</a>.","logo":"logo.png","sceneOptions":[{"navigationMode":"ORBIT"}],"layers": [{"type":"meshPyramid","id":"mesh0","name":"3MXmGeomEnd","description":"Model generated by ContextCapture, copyright <a href='http://www.bentley.com' target='_blank'>Bentley</a>.","SRS": "PROJCS[\"WGS 84 / UTM zone 39N\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",51],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"Easting\",EAST],AXIS[\"Northing\",NORTH],AUTHORITY[\"EPSG\",\"32639\"]]","SRSOrigin": [563231,3954252,0],"root": "Data_1/3MXmGeomEnd.3mxb"},{"type":"meshPyramid","id":"mesh0","name":"Production_1","description":"Model generated by ContextCapture, copyright <a href='http://www.bentley.com' target='_blank'>Bentley</a>.","SRS": "PROJCS[\"WGS 84 / UTM zone 39N\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",51],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"Easting\",EAST],AXIS[\"Northing\",NORTH],AUTHORITY[\"EPSG\",\"32639\"]]","SRSOrigin": [563013,3956063,0],"root": "Data_2/Production_1.3mxb"}]}
Saeid,
I have just had a look at your text and it does look to be correct as this is the case the only advice I can offer is that yo put in a service request and technical support will take a look at your files.
same problem happened to me did the service request made any help on this?
