Greetings,
I'm unable to launch production in Context Capture 4.4.6.845.
The AT went perfectly, but production always reboot my computer.
Does anobody have an idea on how to fix this ? My graphic driver are up to date.
Best regards
open regedit then go to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
Check <TdrLevel> key that is set to (0) which is the value you should have by default. If not edit the value. Contextcapture disables TDR so Windows doesn't reset driver when GPU doesn't respond. Of course if there will be issue then computer may freeze.
Also check Event viewer after restart for logged issues, if there is no issues logged it could indicate failing hardware. What GPU you have?
Thank you oto, the problem has been resolved, my power supply was broken.
