Hello!
I successfully exported Orthophoto in KML format to view it in Google Earth. Everything is fine except "NO DATA" area shown in black :\ how to make this "black" area Invisible?
Please have a look at attached photo.
Thank you!
Transparency is impossible for jpeg compression as it introduces compression artifacts.
The options is still not available in Tiff output.
Why don't you clip the ortho production to the rendered areas when you produce it?
Oto, you usually have good answers to our questions, but this one seems to got stuck without any proper solution. I have the same issue with orthophotos I've created and saved as .tif-files. I can't cut them clean for publishing on our webmap internaly in our organisation. Only tip I found was an old tutorial on how to run a new production adding a limit in the form of an .dng-file. Problem is, I do not want to run another production just to cut the blurry edges of a already made orthophoto. This is a simple task using Agisoft but here in ContextCapture it seems difficult.
https://youtu.be/Q47cntk15g8
You could use retouching to clip unneeded parts or open it in Contextcapture Editor and use merge raster tool to generate new tif.
