I tried to follow this user guide explanation but failed to understand how too :
"ContextCapture Engine
Set the environnement variable CC_MAX_THREADS to define the maximum number of parallel threads executing ContextCapture Engine.
This advanced setting may be useful to preserve responsiveness of other applications running on the same computer (e.g. leave one core for ContextCapture Master if it is installed on the same computer)."
Where is the environnement variable CC_MAX_THREADS ? Could you please help me ?
Thanks.
Hi Thierry,
This system variable will not exist until your create it. To do this go to the Windows Control Pane and select System. Next select "Advanced System Settings. The System Properties dialogue box will appear
Select the Environment Variable button at the bottom. In here you can create the required system variable and set its value.
Answer Verified By: Thierry Terrana
Thank you Felix
