Hello, thanks to Bentley communities for great user support.
I'm working on a railroad project with mobile LiDAR point cloud with no RGB value. I also have structured aerial image data set tied with GCP. Both aerial images and mobile LiDAR are tied onto the same control network.
Because there are many thin objects like wires and steel structures, I need to utilize mobile LiDAR data to get a detailed 3D mesh. Since mobile LiDAR data only has intensity value, 3D mesh only comes in with grey color. when I try to use no color mode on the point cloud panel, it comes out black. even worse
Is there any way that I can use color from aerial images without any color mode from PC? Can I drape orthophoto over point cloud to colorize them?
any advice would be appreciated.
Thank you,
Hi Chan,
Bentley Descartes is offering a tool to colorize a point cloud using image data.
HTH,
Mathieu
