Problem with 3MX mesh model generation in ContextCapture. The cameras and GCPs in the Pruduction appears to be on a line.
I have issues with generating 3MX mesh model in ContextCapture. The Aerotriangulation phase is finished succesfully, I also use GCPs. In the reconstruction, the model still looks ok. (picture 1)
The Production phase is completed without any error or warning, but the created model cant be displayed, after zooming in into the scene the cameras and the GCPs appears to be on one line. (picture 2)
I have had this problem many times in different projects. Sometimes submitting the Production once again with the completely same settings solved the problem and the model looked correctly.  Below is a screenshot of the properties for the Production:
I also attached the exported log  file for technical support. Do you have any idea what can cause this problem? I will appreciate any help, I need to solve this as soon as possible.
Thank you very much!
Block_1 - AT - AT - AT.zip
