What are the optimal GPU settings for Dedicated and Shared GPU Memory?
Within the NVidia Control Panel which CC Program (Master, Engine) should be used to configure the GPU settings?
How should each setting be configured for optimal ContextCapture performance?
Did you ever got an answer?
Frank
