Hi, I am a student and new to Context Capture. I am working on a project which requires me to produce a model in ESRI I3S format. However in the production phase I am unable to select the ESRI I3S format from the droop down list as it is greyed out.
Is there a workflow available to export to ESRI I3S format? Am I doing something wrong or have I missed a step if the option is greyed out?
I have successfully created a 3MX model from the same set of photographs, is it possible to export this 3MX model to I3S format?
Thank you.
Hi Jim,
If you model is not georeferenced the option to export to ESRI will not be available and will be greyed out.
