I see in Project portal status that ContextShare Connection is not established. I am able to upload from CC to Share but it doesn't show up.
How to enable a connection?
ok found that my models are here - https://connect.bentley.com/RealityData not in Project Share
Upload process - https://www.youtube.com/watch?v=y1UOLhouj50&t=106s
3D tiles webviewer - https://connect-realitydataservices.bentley.com/webviewer/?id={guid}
Also got message that "Please make sure you are assigned to a ProjectWise Connected project with 'Use' permission and that Reality models are uploaded to the project" when trying to attach reality model in CCEditor.
Ok set the Use permission but the same issue:
Did you ever figure this out? I'm having the same issue via ContextCapture
Yes see the screenshots, it was because of user roles. Problem is that sometimes only the direct links work.Check here - https://ims.bentley.com/usermanagementand here- https://connect.bentley.com/EnterpriseRoleMgmtand here-https://connect.bentley.com/ProjectRole
Not all roles are set correctly for this to work by default.
