How to recreate the inside of a room using context capture?
Hi, everyone. I am new to context capture and I am trying to recreate a 3d model of the inside of a room. I have a setup with a multi-camera rig (6 cameras that are supposed to do a 360-degree capture every 5 seconds) but when I am attempting to stitch the images together, it's as if it flips the room inside out? Am I supposed to have a different setup when using a camera rig?
The way I am importing the images is I just import the directory of all the images (from all 6 cameras) all together and I left the multi-camera rig to None. The model type is perspective and I put the sensor size and focal size based on the datasheet. The aerotriangulation completes successfully with about 2000 tie points. When I proceed to the reconstruction, the output looks as if the room is inside out. Is there anyway I can sort of invert it so it captures the room as it looks when you're in it?
Sorry if it's a little confusing. Thanks!
