Descartes point cloud edit classification tool needs impprovements
The tool itself works great and is very handy for retouching but needs a bit more powerfull tools for selection.
I felt a bit let down when the "Shape" mode prompts you to input manually points and there is no option to pick an existing shape in the model.
I wanted to separate the asphalt form the rest of the terrain and I had a shape built based on the roadlines and if I  could have used it it would have be a 1 click operation.
Aditionally the shape could have a heigh value so it acts like an extruded volume, similar to the slab. This would avoid picking points from elements such streetlights etc....
