I have a vertical data set consists of approximately 400 photos taken around the building. Aerotriangulation was successful but 3MX reconstruction fails with error message "Image Pairwise selection failure".
I've attached the log for technical support.
Thank you for the support!
Production_2_3MX - Tile_2.zip
Problem resolved. I was remotely accessing my desktop computer and Contextcapture engine failed to recognize graphics card. some kind of network restriction on graphics card i'd assume. Anyhow, problem resolved!
Answer Verified By: Chan Choi
If you need to operate you desktop remotely you can only do so by using a product such as TeamVeiwer. Windows Remote Desktop (RDP) is not supported because hardware acceleration is not enabled.
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/26310/what-are-the-minimum-recommended-system-requirements-for-contextcapture-contextcapture-center
