Greetings all,
My Co. are just starting to use Bentley Connect and Descartes after extensively using V8i SS4 Versions of these products There seems to be issues with:
Creating clips - The point cloud completely disappears?
Viewing Point Cloud sections created with V8i Version: The view attributes default to clip front, back etc off so manually have to change this after activating on each section ,
and there seems to be other issues that I have not yet understood with legacy sections , basically they do not display as they should or at all?
I have gone through usual sanity checks with view attributes, level displays etc. and the issues still persist.
Any feedback at all would be appreciated.
cjm
After 4 months of not using connect version we upgraded connect to update no.10 v10.10 the same problems still exist. We cnnot use the product with sections created in v8i SS4, WHICH IS ALL OUR DATA SET.
Surely we our not the only users having these problems:
view attributes for clip front, back all off when moving from one section to next, changing this and saving setting does not persist and you have to do this agin on each section - totally unusable in a production environment when we are producing thousands of sections.
Also clipping point clouds not working, as previously stated??
Please someone from Bentley give us some assistance with this.
Hi Chris,
Sorry for the delay, I'll have a look.
Would be useful if you could send me some small dataset you have created on V8i that is not working on Connect?
Mathieu
Hi Mathieu,
my first reply ' vanished' hopefully you will see this! it appears i cannot post dgn without error do you have an email.
Any help appreciated with the following:
pod files too big to send as gb's large.
Why does clip volume view attributes default off (so no elements vis when view sections), and not save when turned back on?
Why does clip tools not work on pod files - we must be able to clip mask our pod's?
Why is there a delay in view update, whilst switching between sections, when you have 100's of sections this delay is damaging our workflow? the delay does not happen in V8i?
regards,
Chris
here is a link to file
https://drive.google.com/drive/folders/1RcfX0ChgLtgPDKtJRDkLqgOheI8IIvnY?usp=sharing
