I'm trying to create a 3SM from a corridor-clipped (void) terrain, but get a "Generate operation failed." message.
Is this not currently supported? Any insight is appreciated.
Descartes 10.07.00.22
MicroStation 10.09.00.23
Thank you for the capability confirmation and for the defect information.
Here is a link to the TIN file you requested:
https://studio.bluebeam.com/share/nvywg5
-Mike
Hi Mike,
Haven't time yet to check your TIN yet but if what you want to do is clip out the terrain where a road is passing you could try the Mask capability in the Reality Mesh manager dialog (work but only for mask with limited amount of vertices).
The real solution would probably be to integrate the clipping solution we create for OpenRoads ConceptStation (which would mask automatically the corridor where a road is passing) but this is not yet available in Descartes or MicroStation based Civil products.
HTH,
Mathieu
that's a good point. I may do some experimentation in ConceptStation as well.
I tried masking the 3SM, but it must have had some odd geometry to the shape or too many vertices. It just caused the mesh not to display at all.
Any idea where the vertices' count falloff is? I may be able to simplify the mask geometry enough to keep the low LOD mesh from popping into my proposed roadway in the distance for the most part.
I have tried your .tin file and I am also seeing some problem with the application of the void.
In any case you would be better using some non-destructive clipping.
As for the number of vertices I would say a few hundred max. The mask shape should also not have any overlapped.
Well the limitation is for the Reality Mesh manager dialog mask only. The mask technology developed for ConceptStation can have as many vertices as you want (i.e. : scalable clipping).
Answer Verified By: Mike Dillner
