ContextCapture app was working fine when I was running Android 7.1 on my Google Pixel 2. Upon updating to Android 8.1 as I open the app it only loads a blank screen on startup and crashes itself right on startup. Any solution?
Update: I just wanted to make an update real quick that as I uninstalled and reinstalled the app it has been running smooth once again. I appreciate your time and support Bruneau : )
Shawn YadavShowbox Mobdro Tutuapp
Hi Barry,
Are you using the latest version of the app (update 4)? If not we suggest you to do the update then retry.
Let us know if this solve your issue.
Bruneau
Still happens this problem?
redbox tv
This issue should be fixed in ContextCapture app update 4, let us know if the problem reoccur.
Hello, 192.168.o.1I had the same problem. Thanks for the valuable advice!
Uno rules
Tutuapp
