I am trying to select tiles for production using the 3d view This has always worked in the past but now I can't select one or more tiles with the latest version on CC. Has anyone run into this issue. I notice that the interface for selecting tiles has changed
Farouk Rohoman
This is not the only issue also selecting tie points option is lost. It seems related to recently added feature of "selection by tie point" option. For some reason in simple selection mode it is now hard to check tie point coordinates as it doesn't snap to it but in "selection by tie point" mode it doesn't show tie point coordinates at all.
Hi Oto:
Thanks for the reply. I didn't realize that other functions were affected. I will test
