Adding spatial reference system for reprojection
Hi, I would like to add a spatial reference system in the contexcapture database.  I know How to add one in Microstation but how do I add one in Contextcapture?
And if your asking why? it's basicaly because often when I get lidar data (in .las format) it's already been reprojected but to fit the Autodesk reprojection system.  Sometime the systems are the same and sometime not.  And when the reprojection system do not match in contextcapture when you import lidar data you get the weird tiling-shifting-triangle effect many mention in different post.
So anybody have a clue as to where to start?
