ContextCapture Connect Edition 9, UniqueMeshExport tool now includes boundaries of every tile
Hi, I have noticed that when generating 3D mesh using UniqueMeshExport tool the tiles.txt file contains not only the path to 3D reference model tiles but also the boundaries of each tile. My questions are:
1) is it now possible to combine tiles of different reconstruction settings (in terms of bounding box)?
2) is it possible to uniquemeshexport tiles using "Regular volumetric grid" or "Adaptive tiling"?
  • 1) Not yet....And by then the workflow will be different.
    The bounding box is included because the clipping is done exactly now, even in Uniquemesh, if a polygon is given for the production (that allows to obtain productions clipped properly to the edge) and to do this one needs the polygon.
    2) Yes it is possible because the choice of the UniqueMesh is at the production level now and can be done with any type of tiling.
