Here is the problem.
I generated 3MX in local coordinate system with no geo-reference attached. it created the 3MX with just no units. not metric or imperial. just simple "units"
Then I imported into contextcapture editor to do my edits. I realize objects are much larger than it suppose to be. It scaled everything up based on contextcapture editor setting. I tried to find out what unit it may have used to convert but none seems to match.
I ended up creating the new 3MX with some dummy imperial system (which also is incorrect and potentially cause issue) and used local coordinate values.
Is there any way that I can set the default unit to feet or meters so that when I import it to editor it won't scale everything up by unknown value?
Hi Chan,
Not sure what is the default with no units, maybe it is default to UOR?
Maybe you could try changing the resolution of the .dgn to obtain correct scaling?
HTH,
Mathieu
Hi Matt, I was able to modify the default unit to custom and import the 3MX into the right unit. then I edited in contextcapture editor and exported to dwg. Thanks
