I'm testing a new workstation and I have a problem with selection tool again.
I had the same problem with my actual workstation and have to use the 10.00.00.14 version. I upgrade the driver of graphic card, but I stil have problem with the lastest version.
With the new workstation, with nvidia P4000, and latest driver, I have the problem with the 3 version of Pointools !!
how can I resolve this issue ?
Fabrice
Hi Fabrice,
A defect (Ref:857625) has been logged for this issue.
Fabrice,From my testing in regards to this issue it appear that using any Nvidia graphic driver newer than 2016 has resulted in this issue. Now that just in my case as I was able to revert our GPU driver back to 2015 and it appears to have resolve the issue. However, I do not believe that is a solid solution as new drivers typically offer fixes and improvement, but if you're annoyed by this problem then I suggest rolling back your GPU drivers.
Hi Felix,
I'm experiencing the same problem with the selection tool.
I have a NVIDIA GeForce GTX 1080 card.
Could you tell me is anything happening with regard the defect (Ref:857625) that has been logged ?
This card is one that is recommended by Bentley so it seems strange that there is a problem with it.
Hello Felix,
Have you news about the issue ?
thanks,
There is no update yet on this issue.
