I tried to convert E57 with POD creator.
when I open POD(s) in MS it is well display
However when the same POD(s) is opened in POINTOOLS nothing is displayed...
(Product: Bentley Pointools Version: 10.00.00.17)
any idea why ?
I need to classify each POD and Pointools is more dedicated to that task
thanks a lot for your helps
antoine
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: pointools doesn't display POD that MS can display
can you share the .POD file for review, if so you can use the link below:
https://bentley.sharefile.com/r-reccb8c42a3e42fca
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
