Good afternoon all,
I have gone to start a new production from one of my flights today. I have been able to triangulate the photos but now I have had an error message stating that it has failed to submit production.
"""Failed to push job in job queue FILE:C....................... /TopCon ContextCapture advanced/jobs : Cannot save task definition on disk. """""
Has anyone else has this error message
Please help.
Gav
The path to the project can be found here:
//UK-DCZC72983K8/D$/Drone/Mavic/Section 1-5/180716- Travellers Bund Missing area/Missing Area travellers bund section 5/Missing Area travellers bund section 5.ccm
I believe the path to the project is too long (contains too many characters). Please try relocating the project so that the path is much shorter. Once you have moved the project you will need to run the Reference Manager (under the Project Menu to correct all paths to the project files.
Answer Verified By: Gavin Murby
Spot on working now !!!!!
Thanks for your help.
Kind regards
hi Gav- this just happened to me, sorted it same way as you in this conversation and then realised it was you lol.. hope you are good mate!
