Hey Guys! I'm planning to buy 15 PC. It looks like Ryzen 2700X with 8 cores should do a better job than I7-8700K with 6 cores. However, I'm not sure whether Ryzen 2700X works fine with 1080TI, which is recommended in the user mannul of ContextCapture. Vega 64 should be well compatible with 2700X. But I don't know whether it's performance is good enough. Has anyone tried to run CC engine on a 3A platform? How does it look?
I Attached the hardware recommendation for you, Also 16GB of RAM is the minimum I suggest you to have at least 64GB. You may know that ContextCapture can use Intel and AMD graphics card as well, we recommend to use NVidia GPUs. Keep in mind that GPU is not used during AT process.
PDF
Hi Have you considered the AMD epyc or threadripper processors.. (lots of cores!)
I did. However, it's not an option for me due to budget problems.
Thank you very much!
