Hello! How can I adjust the planned position of the constructed model in Context Capture for example, move it 300 mm to the north?
By adding fake control points. https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/26225/how-to-scale-a-model-without-initial-information
You even don't need to do full aerotriangulation just set Tie points to Keep when running aerotriangulation after adjusting and it will move the model in couple of minutes.
I'm not quite clear. The flight is performed with the exact coordinates of the image centers, the base station gps does not have known coordinates, the alignment was performed using approximate coordinates. for these materials created 3d model. The internal accuracy of the model is good. There is one known point on the terrain. It is necessary to plant the model at a known point.
on one point to move the model is possible?
unfortunately not - https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/123611/contextcapture-simple-move-and-scaleAnyway even if your model is georeferenced you can stillcreate fake GCP to align it. If you need to read other coordinates then just reference in Microstation/CC Editor as reference file in needed position and read the coordinates in DGN which later will be used in CC.
Other option would be to create user coordinate system with adjusted false easting and northing. You would provide this coordinates system and then rerun production with real coordinate system. Which coordinate system you use?
the local coordinate system for my city, it has the known transition parameters to wgs83
