Does anyone know if it is possible to set a spatial framework for LiDAR to be used for reconstruction while having a different spatial framework using just the photos for photogrammetry?
Can this be done all in the same reconstruction or do two different reconstructions need to be done and then somehow merged together? How does one go about merging two 3MX files or productions together?
I would like to use LiDAR scans to reconstruction thin wires but use photogrammetry for the other parts of the model (lower half).
Some advice would be much appreciated, thank you!
BTW the LiDAR scans include everything, not just the wires.
There is setting to use point cloud were available and geometry from photos where there is no LIDAR data. So you can do it in one reconstruction.
New version out too .. auto-align photos to point cloud .. yet to try - but check out video on youtube.
Hello I give a try to the new version with the test case. I follow the instruction but it is not possible to use "point clouds for adjustment" !!!!
the pictures are georeferenced and I don't know how to have "position only" as in the video. Maybe someone can help !
Cheers,
Fabrice
Did you ever get this to work or has anyone been able to successfully line up the photos to the point cloud?
