I am experiencing a problem when attempting to generate a ground extraction using Context Capture Editor.
As soon as I left mouse click to accept the reality model I get the following error message;
'Unable to load dialog from 'DCPOINTCLOUDAPP' whose id is - 172' (see appended screen grab)
Could this be a setting issue?
Hi Rodney,
Hmm seems to be an install issue. Have you tried reinstalling the software?
Also what version are you using?
Mathieu
Hi Mathieu,
Thanks for your response.
I have tried reinstalling the software, Update 2 but am still getting the same error.
Further update.
Based on your comments I once more uninstalled the program and deleted all related, remaining files manually and then reinstalled.
I also reran the reality model in CC and now everything works as expected.
Obviously there was something that it did not like.
Thanks once again for your help and support
