hi.
I am trying to get orthophoto with the contextcapture editor.I want to do orthophoto in a split way with high resolution grids.merge options - how to use the grid definition sectionI do not know how to produce a grid.
Hi Ahmet,
Below is a grid stored in test3dGridDefinition.dgn (2 green rectangles and 2 white texts) and the orthophoto to grid attached to test3d.dgn (for display purpose the test3dGridDefinition.dgn is attached as a reference).
In the Grid Definition textbox I specified test3dGridDefinition.dgn and the Merge tool created 2 orthophotos called grid1 and grid2.
Mathieu
Answer Verified By: ahmet guner
hello your answer was the answer to your responsibilities. thank you. Could you please send me the example of the photo?
Sorry I am not understanding. You were not able to do want you want with the information above?
No no Your response is very good.
Could you send the grid's CAD?
Here is the grid example.
