Receiving an error on all tiles when submitting production. No issues with aerotriangulation. Errors shown below:
Also unable to produce error log for some reason. Receive error: "LibZip encountered an error: Renaming temporary file failed: Permission denied.
Any help would be appreciated, thanks.
C-drive full? When I see zips failing - first thing I check is the windows temp drive space .. bearing in mind the size of thing that is being zipped.
In many cases this error can be caused by a lack of disk space on the project or worker disk. If disk space is good the cache has likely become corrupted from previous error. Also it may be caused by bad video drivers or hardware.
Also check that driver upgrade has not changed TdrLevel value in registry - https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/126763/contextcapture-windows-timeout-detection-and-recovery-tdr-error/386352#386352
Afterwards please delete the following files and resubmit your production:
\Project files\Block_8\cache\EB\*.a3d
