Hi All,
Having great and extremely frustrating time processing orthophotos inside Context Capture Editor.
Every time I try to produce one of the above to a good level of detail, 1cm resolution, I get "Operation cancelled by user" and then the program crashes.When running at a lower resolution it will produce sometimes but the resolution is so low it's pointless as a deliverable.
Has anyone found a way to successfully create high resolution orthophotos/orthoplanes using CCE, image size of apx 20,000 x 20,000 pixels?
Computer specs i9, 128gb RAM, 2 x 1080ti
Any help is much appreciated.
Thanks,Brendon
I'm having the same issues. I was able to produce vertical orthophotos but then suddenly it stopped working, even thought I was using the exact same reality model and resolution.
It will display "Operation cancelled by user" but it will create a geotiff with the filename I've choosen and it will be about the right filesize, but when I open it it's a pure black image.
Sometimes afterwards I will be unable to view my reality model afterwards. The view just goes pure white and no matter how you scroll around you can't get the model back. You have to close CC Editor and re-open to get it to appear again.
Hi David,
Hmm not sure but have you tried clearing up your temporary file?
Have you tried reproducing the problem on other computer?
Mathieu
Mathieu, this issue is still plaguing us. CCE has proved to be a real headache for us, what is our best option for getting support to resolve this outside of the forum?
Please go to https://connect.bentley.com and log in to create a service request. Bentley Technical Support will then assist further
Hi Felix,
Moved to Update 3 but still running into the same issue. Ticket has been logged.
