We have a question with Microstation V8i now, it was confused, i want to ask if you know the issue.We receive some las data from Japan, we used function of "Open Location in Google Maps" as follow steps, 1. Set the Geographic Coordinate System, select JGD2000 Plane Rectangular CS3 2. Attach las as POD in Microstation.3. Open Location in Google MapsBut the Latitude and Longitude is not correct, we try to found why cause this issue.Under Microstation/GeoCoordinateData/Japan folder, there is a file named TKY2JGD._jg which has been created by using "Open Location in Google Maps".We try to install Microstation on the other PC which never installed Microstation, Use "Open Location in Google Maps" function, the location is correct,We found that the new installed Microstation don't create TKY2JGD._jg file in Microstation/GeoCoordinateData/Japan folder.
