Tie point not calibrated properly,
1. We have used Sony Alpha 5100 with 16 mm lens and the data acquired at 120 meter from Ground.
2. 20 Sample images of mid trajectory, processed and the camera model was saved.
3. Entire images are processed using previously saved camera model, even though the images are not calibrated. kindly provide the best solution.
Try this:
communities.bentley.com/.../the-model-appears-to-be-curved-instead-of-being-horizontal-after-at
You can't correctly calibrate camera using only nadir(vertical) photos.
