Hi, my name is Dahye from S.Korea.
I took nadir aerial images and oblique images together using a drone.
I put both kind of images together in ContextCapture and the aerotriangulation always failed to align all photos.
If I put only nadir or oblique images, all photos are aligned well but when I put both kind of images together, nadir photos can't be aligned.
I've checked this kind of problem in other projects either.
Attached are the 3d view file than you can review it.
I am not sure if I should change some kind of setting parameters..
orange camera images were taken in vertical degrees(-90degree) and they are not aligned.
aligned images coloured yellow were taken in oblique degrees(-30degrees-0degrees)
Thank you very much in advance for your reply.
You may have to do them separately using different aerotriangulation parameters and then later merge blocks using real or dummy GCPs.
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/26225/how-to-scale-a-model-without-initial-information
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/26852/merging-models
